residential architectural visualization
jhayarsamson
  ishpalsingh said:
don't use models for trees and people use images instead,they will give a better look to ur renderings
But if you are going to, use higher detail ones.
Generally, the tiling of some of your maps needs looking at, especially on the roof and some of the stone walls. You can either see the edges, or the repeating pattern.
Also, it looks like you are having problems with your IR map, thats possibly why you are getting the bright spots on your image. Could be a light thats causing that..
The detail on the model needs a bit more, like adding a gutter or extra line to the edge of the roof. Adding a kerb to the road, and a "gutter" to the road where it meets the kerb..
I havent got into HDRI's yet, so cant really help out on anything that way..!
