mskin Posted February 6, 2007 Share Posted February 6, 2007 does anyone know why i get the funkyness with this boolean operation. essentially a mass and 72 planes, meant to intersect eachother so that the planes wold fit neatly inside the volume. as the images show...there is something funky going on here. Link to comment Share on other sites More sharing options...
Brian Smith Posted February 6, 2007 Share Posted February 6, 2007 that's odd...shouldnt be doing that...load er up and i'll have a look see Link to comment Share on other sites More sharing options...
mskin Posted February 6, 2007 Author Share Posted February 6, 2007 thanks Link to comment Share on other sites More sharing options...
LKlemenc Posted February 6, 2007 Share Posted February 6, 2007 Why don't you try booleaning with ProBooleans (they are included in Max9). Max's native booleans haven't changed from the first ver. of Max. Link to comment Share on other sites More sharing options...
mskin Posted February 6, 2007 Author Share Posted February 6, 2007 i tried that. probooleans has given me some really rgeat results... cleaner meshes. for some reaon i had less success with the intersection boolean - everything just dissapears. Link to comment Share on other sites More sharing options...
Brian Smith Posted February 6, 2007 Share Posted February 6, 2007 worked fine for me...don't know why it didnt work for you...maybe try rebooting your computer...sometimes that just fixes strange things Link to comment Share on other sites More sharing options...
mskin Posted February 6, 2007 Author Share Posted February 6, 2007 Brian, still, why the imperfections (attached images). I can see why the narrow sides might be giving me issues, the four corners that border it are non coplaner, perhaps triangulating them will will help... ill give that a shot. But the last image shows where the intersection command didn't work quite as planned - in a triangular face. some of the slab edges are protruding out of the solid. the solid is a copy of the form used in the intersection so if the intersection worked correctly, i shouldn't be able to see it. There is something fishy with these booleans. Link to comment Share on other sites More sharing options...
Brian Smith Posted February 6, 2007 Share Posted February 6, 2007 i wasnt looking for these imperfections so i didnt notice them...i am rendering on my machine right now and i'm heading home...i will take a look at it again in the morning Link to comment Share on other sites More sharing options...
daniohayon Posted February 7, 2007 Share Posted February 7, 2007 still, why the imperfections The first thing about your model is that it is not ready for the boolean operation. The second thing is that you are trying to substract an object that hase no volume. That's why it dissapear when you use Pro. I took half of the planes and fliped the faces upwards, selected every two borders from top down and bridge between them. resulting in a bunch of boxes (half in number from the planes). Then Pro with substraction option (made a copy of the building first) . Then with the Window/Crossing selection tool, I erased the walls left overs. Ending up with the planes you need. I'm at work in lunch break and can't send you the file because we don't have winzip on the system I'll email it to you if you post your address. Link to comment Share on other sites More sharing options...
Brian Smith Posted February 7, 2007 Share Posted February 7, 2007 got it to work fine after subviding both objects a little...i use the default value for the planes and 5m for the body object. booleans don't work good with long and skinny faces which is what you get when you dont have a dense enough mesh Link to comment Share on other sites More sharing options...
