Aquatics
esilvis
Hello,
Aquatics illustration...All critiques appreciated.
Work in progress:
lighting recessed cans behind slide on sloped roof
slide columns, and few other item to address.
Thanks for the forum....
Eric Silvis
Water Technology Inc.
acad
max
photoshop
poser 5
dual 2.0
1 hr render time
http://www.cgarchitect.com/forum/filepush.asp?file=INT-POOL2.jpg
[ July 14, 2003, 08:33 AM: Message edited by: esilvis ]
Hi esilvis,
That looks like a lot of fun..
I only have one complaint.. first it took me quite a while to figure out what was wrong with your image.. and its the weird beveled roof you have happening , but more specifically its how it works into the corners,and the glass , then into the walls .. something just doesn't read right in that top left corner above the glass and the roof line.
do you know what I mean?
nichchris
The corners look fine to me. What is really funny is where those open-web joists end....there must be some kind of massive beam hidden above. I think the finished clg. on the slope part should most likely start from the bottom of those joists rather than the top - altough that is where you whould normally seat the joists (top member). It would look better to butt-joint the joist into some kind of soffit. That's jsut being too picky....
I like the slide very much.
Xavier
thanks for the interesting critiques. I could have provided more information on the architecture and pool design...so here goes.
My background is in architecture. I have recently
started doing 3d work for an aquatic design and engineer firm. I havent seen to many water parks in this forum, just thought I would post one.
I built this model using drawings supplied from the architect and aquatic design from in-house.
Slides and play structures are meshes supplied from manufacturer.
The camera angle shown in the illustration shows several design elements of the indoor water park. The main focus is the slide and plunge pool area (could use a kid a coming down the slide). Other activities are the current channel, kids activity area and lap pool.
My job is both interesting and challenging. Part of the challenge in my illustrations is to provide a sence of aquatic atmosphere, architectural space, and 3d realism. Max elements of water and lighting makes for an interesting challenge by themselves.
As to the critiques, the walls and roof structures are in the proper place. see section for beam and roof construction.
Thanks again. Great place to be.
http://www.cgarchitect.com/forum/filepush.asp?file=POOL1-section.jpg
Eric
There is a beam where the joists are seated, but the material needs to be differentiated from the ceiling material. Then the roof behind will read better as it soars above and behind. I assume there is a clerestory above that beam.
Eric
As I just noticed the section, you have already answered that question. :angeuhoh:
The overall effect in your picture is dull. If you can get some bouncing light it would really help. You know in real life sun hitting a pool will produce great caustics on the pool below the water and reflected onto the walls/ceiling. Without actually calcing these you can use a water caustics image--there was a link here recently to a 'generator' (but I don't have it handy) and an image map can be projected and an eyeballed 'bounce' angle off the water towards the ceiling, and also to the pool material below water. But you may not have the budget for such stuff.
I also wonder if you couldn't find a more dynamic view. How about moving image-right so the slide is big over your head with the light pouring in from your left/behind you. The current view does not suck, but I think you could do better.
With the architecture clarified....on to the quality of image and dramatic views.
Thanks Ernest for your critique....I agree that the image does lack a dynamic view at this point.
This camera view was set up to show off the four elements of aquatic design. I can development individual dramatic views for the four elements.
But at least the current view doesn't suck.....lol
As far as bounced lighting...very good point.
Not sure about the "generator" but I am experimenting with advanced lighting override on the water material. We'll see what happens.
Thank again...great place to be
Eric
