SunGlare Posted February 8, 2007 Share Posted February 8, 2007 I'm playing with pool water mtl, and have no succses story. Anyone can help? Outside poll, distant 40 -50 from camera. Daytime. Link to comment Share on other sites More sharing options...
ApeiNe Posted February 8, 2007 Share Posted February 8, 2007 Try >> THIS Then go in Tutorial, Vray pool setup Link to comment Share on other sites More sharing options...
SunGlare Posted February 8, 2007 Author Share Posted February 8, 2007 This Is something that I have now.... Its caustics. Link to comment Share on other sites More sharing options...
ApeiNe Posted February 8, 2007 Share Posted February 8, 2007 Do you want to have caustics ? Just use teh caustics generation in Vray, using photon map could be a better way to get great caustics, but also hard to manage BTW, i prefer use something like this Caustic generator, just have to generate and apply it to you swimming pool material Link to comment Share on other sites More sharing options...
novelh Posted February 16, 2008 Share Posted February 16, 2008 Under what parameter in the water material would you apply the "caustics generator" output file to get the effect? ApeiNe said: Do you want to have caustics ? Just use teh caustics generation in Vray, using photon map could be a better way to get great caustics, but also hard to manage BTW, i prefer use something like this Caustic generator, just have to generate and apply it to you swimming pool material Link to comment Share on other sites More sharing options...
Eric Sosa Posted February 16, 2008 Share Posted February 16, 2008 don't make it complicated....get a pool water vraymaterial at vraymaterials.de...easy Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 16, 2008 Share Posted February 16, 2008 Disagree. Better learn how to do it yourself than depend on other people's skills. About the caustics, there are many ways you can get fast, accurate caustics with VRay. But, if you don't want to get too complicated, you can create a standard light and apply the map created with the Caustics Gen to it as a projector. Very easy and fast. Link to comment Share on other sites More sharing options...
novelh Posted February 16, 2008 Share Posted February 16, 2008 Rick Eloy said: Disagree. Better learn how to do it yourself than depend on other people's skills. About the caustics, there are many ways you can get fast, accurate caustics with VRay. But, if you don't want to get too complicated, you can create a standard light and apply the map created with the Caustics Gen to it as a projector. Very easy and fast. Thanks. I'm using MR by the way not Vray. I'm not sure that method will work with the mrSun. If I was to do it a secondary light in the scene wouldn't that affect the environment around the pool in addition to the water or should I exclude everything except the water in it's illumination? Link to comment Share on other sites More sharing options...
znotlin Posted February 17, 2008 Share Posted February 17, 2008 novelh said: Thanks. I'm using MR by the way not Vray. I'm not sure that method will work with the mrSun. If I was to do it a secondary light in the scene wouldn't that affect the environment around the pool in addition to the water or should I exclude everything except the water in it's illumination? erhhhhh..... Dude, no offense, but you may have better luck in the mental ray forum. Link to comment Share on other sites More sharing options...
nilariver@gmail.com Posted February 17, 2008 Share Posted February 17, 2008 Use v ray material and in bump you can use some water body image. I got good image compared to this Ajith kumar Link to comment Share on other sites More sharing options...
