mskin Posted February 15, 2007 Share Posted February 15, 2007 i think this is a mental ray issue. I want to render a building with a site background. there is lots of glass in the building so i need to see the site beyond. when i replace the physical sky background with a tiff, it doesn't render. USE MAP is checked, so im really not sure what the deal is. Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 16, 2007 Share Posted February 16, 2007 Have you tried a Jpg instead, Mental can have problems with tiff (not that I have experienced any of them) There is also an option to drop a map into the Physical Sky, cant remeamber where and as I am rendering at the moment cant check. JHV Link to comment Share on other sites More sharing options...
nisus Posted February 19, 2007 Share Posted February 19, 2007 Mental Ray can't read tiffs with a LZW-compression (because they don't agree with the copyrights of the compnay who does the LZW - they would have to pay some insane amount, so they simply don't support it!) This won't give a lot of problems because one can simply avoid the LZW. Anyway, if you are using Xfrog voor trees & shrubs, beware to convert your files!! For background issues: Add a physical sky, drag the map into the material editor, and add a map in the 'use custom background map', next DON'T FORGET to turn OFF Aerial Perspective (in your camera properties). rgds, nisus Link to comment Share on other sites More sharing options...
Hatem Sayed Posted February 15, 2008 Share Posted February 15, 2008 if u r using max 2008 with mr exposure control.dont use the physical units and use the unitless sitting and make it about (60000) Link to comment Share on other sites More sharing options...
