al_farooq Posted February 16, 2007 Share Posted February 16, 2007 hi all, i want to modell a room then wants to make frames on walls and columns with crafted crown what should i do how i can make frames on wall and columns on wall as in attached file if my friends can explain with pictures that will b best for me it is not must that i wan t make same attached wall decoration i want to know how i can make like these frames and columns and how i can make ceiling as in attachement picture i will b thankfull to cg members and guest which will like to help me Link to comment Share on other sites More sharing options...
al_farooq Posted February 16, 2007 Author Share Posted February 16, 2007 hi all, i want to modell ceiling like in attached pictures pls teach me how i can modell like that ceiling by 3dsmax software and which r important points which should remember at the time of modelling of ceiling Link to comment Share on other sites More sharing options...
sterealkey Posted February 16, 2007 Share Posted February 16, 2007 You could draw a basic spline (sliced view), or side profile of the 'cornice', and then draw a spline in top view the shape of your room, which is usually rectangular. And then use your sweep modifier, and select your shape(sliced view) as the object to be extruded along your spline. Sometimes needs a little tweak afterwards, but this should give you the result you're looking for. Peace. P.s. I'm not english, I'm Afrikans - so I mightve used the wrong terminology, but I hope you get what I was trying to say Link to comment Share on other sites More sharing options...
sterealkey Posted February 16, 2007 Share Posted February 16, 2007 You can use the same method that I suggested in your ceiling thread. Draw the profile as a spline, and draw a path in the shape of the frame, then apply sweep modifier with the profile as the base object. Might need one or 2 tweaks afterwards, so for that you will convert to editable poly and then edit it. Are you familiar with polygon modelling. i.e. Editing objects without modifiers? Link to comment Share on other sites More sharing options...
al_farooq Posted February 16, 2007 Author Share Posted February 16, 2007 hi my friend sterealkey thanks for reply happy to c ur answer what u mean by sliced viewand where r u from from africa Link to comment Share on other sites More sharing options...
STRAT Posted February 16, 2007 Share Posted February 16, 2007 please keep all these similar posts in 1 thread. not 4. thank you. Link to comment Share on other sites More sharing options...
