Reactor Problem
geardaddy1
So, I am trying to add animated flags in my scence per clients request. Here is the problem. It should be a easy four step process using Reactor/RB/Cloth/ and wind right? My flag blows up. Goes crazy, polys flying everywhere. Is there a trick. I even did the cloth tutorial on this site with no luck. I am using max 8.3.
Please help, Thanks,
Dave
had a similar problem...that covered wagon tut should give you the proper constaint that's causing the crazy poly thing...that's how I figured it out...if I remember it's like one little check box...couldn't find that sample scene for reactor but I give you an alternative method...flex modifier...here's the scene
Thanks Rick,
I also thought that, but nothing seems to work. The flag will fall correctly if I don't have it constraint to a rigid body, but man, when I select a vert and attach it to a Rigid body it freaks.
Who knows, I have tried a few other tutorials out there, and I feel like I am correctly doing it, it just is not workin.
