masone Posted February 16, 2007 Share Posted February 16, 2007 Link to comment Share on other sites More sharing options...
gfa2 Posted February 16, 2007 Share Posted February 16, 2007 What is your rendering engine? What way are you using to get your sketchup model into your rendering program? Link to comment Share on other sites More sharing options...
jophus14 Posted February 16, 2007 Share Posted February 16, 2007 You can export SU as a 3D model and import then into other software, then render it with whatever software you are using. Link to comment Share on other sites More sharing options...
masone Posted February 16, 2007 Author Share Posted February 16, 2007 yow i the export as a 3d modelit was all done in sketchup... it a plugin for sketch up... Link to comment Share on other sites More sharing options...
jophus14 Posted February 16, 2007 Share Posted February 16, 2007 Are you using Podium? Link to comment Share on other sites More sharing options...
masone Posted February 16, 2007 Author Share Posted February 16, 2007 yes i am Link to comment Share on other sites More sharing options...
gfa2 Posted February 17, 2007 Share Posted February 17, 2007 You can export SU as a 3D model and import then into other software, then render it with whatever software you are using. Yeah, I've done that before but it never seems to work out for me. Especially on larger more complicated scenes. Usually if I'm trying to do this it's with a model that someones has created and I don't have any control over how they've done the modeling. Sketchup to 3ds max just always seems to be an unpleasant experience for me. Any more specifics on the export settings or other things to watch out for would be great! Link to comment Share on other sites More sharing options...
P.R.S. Sivakumar . Posted February 17, 2007 Share Posted February 17, 2007 Try the same model in Kerkythea 2007 rendering engine - which is an absolutely free and amazing software. Link is http://www.kerkythea.net You will find it in the downloads - also the plugin SU2KT to export from SketchUP. Greetings PRSS Link to comment Share on other sites More sharing options...
AJLynn Posted February 17, 2007 Share Posted February 17, 2007 Yeah, I've done that before but it never seems to work out for me. Especially on larger more complicated scenes. Usually if I'm trying to do this it's with a model that someones has created and I don't have any control over how they've done the modeling. Sketchup to 3ds max just always seems to be an unpleasant experience for me. Any more specifics on the export settings or other things to watch out for would be great! It's all about the quality of the original Sketchup model - check for reversed faces, coplanar intersecting faces, things that should be welded that aren't, other geometry errors, correct UVW mapping, good use of grouping and layers, etc. With a good model it always works well for me. Link to comment Share on other sites More sharing options...
deevee84 Posted February 25, 2007 Share Posted February 25, 2007 how do u do somethig like this?!?! i need to learn sooo much !!! Link to comment Share on other sites More sharing options...
jvlive Posted March 2, 2007 Share Posted March 2, 2007 yeah, how do you go about modeling an interior in sketchup? Link to comment Share on other sites More sharing options...
