Follow Me Tool problem
rcase
I am working on a spiral shaped ramp to a pedestrian overcrossing. I've attached a couple of pics to illustrate my problems. I'm using a flat rectangle to extrude but when it get towards the end of the spiral path its tilted dramatically. I've tried starting at both ends, results are the same both ways. Does anyone know how to keep the shape flat going all the way up the spiral path? Thanks for the help.
Rusty
The reason for this is that your spiral path is also rotating about its own z axis, so the profile that you are using the Follow Me tool on stays perpendicular to the base axis, hence the "banking".
No fix for this exists that I know of, however, if you set the banked spiral away from the upper platform yo are trying to connect to, you can then connect the points of appropriate corners with lines to make faces that will then graduate back from the banking to the horizontal.
