Macpod Posted February 17, 2007 Share Posted February 17, 2007 Lets say i want to draw a guide line for a loft. What is the best way to draw a line in the z-axis? Theres alot of stupid ways like waving the crosshair around until it lock in the z-axis or typing in co-ordinates. Is there a more intuitive way of locking the z-axis? like a shortcut key? I suppose i can switch the UCS, but then its locked in the Z/X or Z/Y axis.... cheers Link to comment Share on other sites More sharing options...
STRAT Posted February 17, 2007 Share Posted February 17, 2007 drawing in the z axis is drawing in 3d in essence. and as you say, there are a million and 1 ways of doing this. they're only stupid to those who are new to it or aren't autocad familier. to a regular user these 'stupid' ways are everyday essential drawing methods. you use what method is needed at the time to get the job done. but, if you just want a fast method of drawing a straight line up the z axis, then, imo, the quickest way is to rotate the usc to suit. (this is quite normal in 3d acad drawing btw). type: USC then F (or RI or L etc etc) this rotates the usc to front or right or left for example. draw your line, then remember to do UCS and W or P to get it back to world or plan. Link to comment Share on other sites More sharing options...
Macpod Posted February 19, 2007 Author Share Posted February 19, 2007 wise words. I had hoped for something like the lock axis command found in sketch up but this isnt too bad. good hint about the USC shortcuts, almost forgotten about them. Link to comment Share on other sites More sharing options...
JamesTaylor Posted February 19, 2007 Share Posted February 19, 2007 if its only a single line to be drawn you can also specify it using relative co-ords, click for the start point then @xvalue,yvalue,zvalue i.e @0,0,1000. this can only be used for lines and not polylines Link to comment Share on other sites More sharing options...
