mk3ds Posted February 19, 2007 Share Posted February 19, 2007 Hi, I'm having trouble with Vray. When I render the stuff, I always get this patchy areas on the wall and light coming from corners. I have shield all the corners so there isn't any gaps between and funny thing is when I render it on other computer, it renders it fine. Could you please help me out or have any idea what is wrong?? Thank you Link to comment Share on other sites More sharing options...
kippu Posted February 19, 2007 Share Posted February 19, 2007 try with higher irradiance map settings and see if it comes? Link to comment Share on other sites More sharing options...
mk3ds Posted February 19, 2007 Author Share Posted February 19, 2007 Kippu I've tried with higher irradiance but got worse... I've tried override the material but I don't think it's to do with them either. I've been having a same problem for ages and this is driving me insane! It's always light coming from right hand side. Link to comment Share on other sites More sharing options...
martin walker Posted February 19, 2007 Share Posted February 19, 2007 also make sure your geometry is tight...weld vertices on the corners, or at least make sure there are no seams...but its probably a change in your GI settings thats needed Link to comment Share on other sites More sharing options...
devgun Posted February 26, 2007 Share Posted February 26, 2007 can u post the image of your irradiance map settings.?? may be then we can give you some solution... but make sure your model is completely closed. Link to comment Share on other sites More sharing options...
