autocad to rhino 3
vildvittran2
When I try to open (or import) a DWG-drawing (autocad) into RhinoI only see the drawing in the top view. (sometimes I manage to view some of the lines in the other views). It is impossible to extrude a surface in the drawingarea. But if I try to do that outside the drawingarea it works(!). So my main problems are: why is not all my lines viewable and why can't I extrude something in the drawingarea? I really hope that someone can help me....
Hej Anneli!
I'm not sure why you're seeing this, but it shouldn't happen. Perhaps the other views are not showing the same portion of the model - have you tried "Zoom Extents" in the other Rhino Windows?
If this doesn't help, you could try sending the model to me - along with the DWG file you are importing and I can see what's going on.
Best Regards
Andrew le Bihan
Robert McNeel and Associates
http://www.mcneel.com
http://www.rhino3d.com
http://www.accurender.com
Thank you for your answer, but I have solved the problem by importing the file into Archicad instead.
/anneli
Hej Anneli!
Best Regards
Andrew le Bihan
www.mcneel.com
www.rhino3d.com
www.accurender.com
