Saving pdf files
jtroupe
I am working in Photoshop CS2 on a presentation brochure. I need to save about 30-50 files as pdf's that I will then assemble in Acrobat to be able to e-mail.
The problem I am having is being able to save the files at a good enough resolution to be readable and not too pixelated and then small enought that when I compile a lot of them that it isn't too big to e-mail.
I have tried several methods, but the best one that I could come up with was opening my psd files in illustrator, converting the layers and then saving it as a pdf. It works fine for images, but the text doesn't translate over very well. And it takes forever.
I have also tried to print to Adobe PDF thinking it would make a smaller file size, but it just got bigger. I used the smallest file size setting when saving it as a pdf in Photoshop, but then all the images are very pixelated and the text isn't.
Anyone got any better options or a great solution??
Thanks
Depends on the resolution youre trying to acheive, but by the sounds itll be WAY too big to email....30-50 images? Just as JPG's imagine how big thats going to be. Making it a PDF doesnt make it magically smaller.
Id recommend just saving every page as a TIF (if theyre already rasterised) in the res you need, then just drag them all into Acrobat Pro. Itll prompt to make it all 1 PDF, then off you go.
Promise you its gonna be a biggun tho! Maybe have to split it up into a few PDF's, in that case just drag as many of the images into Acrobat Pro as you want.
Ive had sleepless nights with the same thing.
After lots of experimentation Ive realised that its better to do it in a vector program (I use Corel Draw), and then publish to a web friendly PDF.
This way all your text will remain text and not be rasterised, your graphics will be compressed to give you an acceptable filesize.
I know its too late now, I'm just saying that maybe in future try to stick to vector where you can.
Peace
