Michael Emo Posted February 20, 2007 Share Posted February 20, 2007 Hey everyone, I have a quick question regarding OUTPUT SIZE. How big would you output a rendering if the final version was going to be printed at approximately 24x36 in size on an inkjet printer? Also, would you use the Frame Buffer to determine resolution or 'Get resolution from MAX' ? Thanks for any info you could provide. Michael Link to comment Share on other sites More sharing options...
JamesTaylor Posted February 20, 2007 Share Posted February 20, 2007 24 x 36 ??? mm, cm, metres, inches, feet, yards???? i'm guessing it'll be cm or inches since its inkjet, so i would suggest at min using 150DPI with 300DPI being a pretty universal standard for graphic works to be printed. you should be able to work out the required size from that, i.e if its 24 inches wide at 150 dpi then you need to render a width of 3600pixels Link to comment Share on other sites More sharing options...
Michael Emo Posted February 20, 2007 Author Share Posted February 20, 2007 Oops. 24in x 36in. Thanks for the quick feedback! Michael Link to comment Share on other sites More sharing options...
BrianKitts Posted February 20, 2007 Share Posted February 20, 2007 check out this thread..... http://www.cgarchitect.com/vb/21723-what-size-do-you-render-stills.html Link to comment Share on other sites More sharing options...
