vray sky help
tanuki1965
Hello everybody,
I am trying the vray 1.5 rc3 demo with 3ds max9 and I can't succeed to
have a decent sky, I mean there is no gradient colours in my sky .....I tried to
tweak the rendering panel but no way ! In my skymap in the material
editor I can see the gradient coulors but when I render it's just one colour.
I followed many step by step tutorials and I never can get the same "gradient sky
look" that result of the tutorial !
Please could anybody post a simple vray 1.5 scene with a plane and a sphere and a vray sky and sun preset ? It would be a great help for me.
Thankx a bunch !
Yes Antonio, it's very weird that nobody answers. I looked on the net for a vray 1.5 scene to download but I could not find. I just wanna load the rendering presets of the scene and apply the presets to my scene to check what is wrong..I hope somebody will help us.:)
bye.
I ran across a short video tutorial from evermotion (i believe)... I will look for the link and repost when I find it
I will check shortly to see if I am remembering correctly. I also believe the new evermotion Archexteriors are using the vray sky? i could be wrong... just trying to think of where I mightve seen this used :-P
Thankx for your help Rick and Eric !
I saw a vray html tuto on the Evermotion site and I followed
it but It did not work well, still looking for a vraysky&sun scene
to download to be able to analyse the rendering presets.
Yes Eric, the "Affect Background" option on the Color Mapping is checked, but
no way, the sky is still a simple blue shader without nuance or undertones.
Take care,
Hi Phil,
here are to situations done with VRay Physical Camera and a VRay Sun (at 2 diferent low positions) and with VRay Sky in the Environment Map.
I made the teapot reflective so the sky gradation coul apear on in a little bit.
Are you using the VRay Cam? Max Standard Cam wont take all of the new VRay Sun and Sky, I think (?)!
Sincerely,
Joao
I had the same problem...the scene is illuminated but the sky looks too dark?
If that is the case, the video tutorials on the vray forums can help you out:
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17824
It has a lot to do with Linear Work Flow. The whole video tutorial series is very helpful, but in a nutshell what you need to do (if I remember correctly is this):
Instance your vray sky from your environment to the material editor. Click on VRaySky and change it to an output map (while keeping VRaySky as a submap). Toy around with your Output Amount.
Of course, the downside to this whole thing is now your scene is overly blue from the sky....the tutorial goes into how to fix this, but it's too hard for me. I ditched the whole sky thing.
Here is a 2 min clip showing how to create a vraysun and skymap. I'm really not sure what you're doing wrong because there's not much to it. You don't have to use a vray camera, you dont have to touch anything in the Render Scene dialog box (except enable GI), you dont need to touch the material editor...you really don't need to do much.
http://www.3dasdev.com/vraysun.mov (24MB-may take a minute to load)
Honestly Brian, I still don't understand what went wrong, moreover I did not change many settings in the rendering panel to make it work...now I need
to improve the use of the vray camera settings (even tough If I don't use a vray cam it's working well). Maybe the Vray plane I added made the difference....but I don't think so. I changed the gamma settings too.
Thanks to you Brian.
Phil,
Just my opinion so take it with a grain of salt. I would recommend not worrying about using the vraycamera if you are not at an intermediate/advanced level of work. Obviously it's a great feature, but it's totally not a necessity. Max cameras work perfectly fine and for most people are easier to manage than the vray camera. You're just adding more variables to an already complex lighting program. With Max cameras you dont have to worry about settings that will affect the lighting in your...or at least the way the lighting appears. I would recommend using the vray camera only if you are totally up to speed on all the other main vray lighting controls.
With that said, as the Chaos manual states, the VRaySky does give its best results with a VRayCamera, but i would argue the rationale of complicating things for the sake of this.
Brian,
Do you now use the vray sun and sky for your exterior scenes systematicaly or do you still light your scenes with vray lights (planes, domes and spheres). What do you prefer?
Phil,
  • 3 weeks later...
Patrick,
i only spent about 30 sec on this but here is a skymap with a standard camera. i can only assume that you have not changed the default 1.0 skymap multiplier that would work fine with a camera that has exposure control (i.e. the vray camera), but not with a standard camera
  • 1 year later...
