kwerch Posted February 22, 2007 Share Posted February 22, 2007 Hey all- Don't know what is up but when I started rendering a scene this morning using vray 1.4.7 and Max 7, max crashes. It looks like when it gets to the light cache part of the calcs that something happens. Memory spikes at this point. I turned off materials and it renders fine. Best I can figure is I have series of bitmaps that exceeds the amount of memory that I have available(2gig) sooo...any suggestions? thx. Link to comment Share on other sites More sharing options...
Mike T Posted February 22, 2007 Share Posted February 22, 2007 I've had that problem with a couple of scenes. It helped alot to raise my virtual memory to around it's maximum. Actually, since I've done that, only RPC's crash rendering. It might solve your problem but that's the only suggestion that I have. If you need directions on how to get to your virtural memory let me know. Link to comment Share on other sites More sharing options...
kwerch Posted February 22, 2007 Author Share Posted February 22, 2007 Yeah Mike, could you tell me how to get into that? thanks- Link to comment Share on other sites More sharing options...
Mike T Posted February 22, 2007 Share Posted February 22, 2007 Sure.... if you right click on "My Computer" in your start menu and go to properties you'll open the systems proporties window. From there, you'll go to advanced tab and under performance hit settings. This will send you to the Performance Options.... go to the Advanced tab and then go to Virtural Memory and hit Change. In the Virtural Memory window you'll see at the bottom minimums and recommended. This what is suggested to place in the custom slot. Mine is at 3096 initial and max at 4092. But you can set it a little higher or lower if you need. Again, this helped me in my crashing and hopefully it will help you. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 22, 2007 Share Posted February 22, 2007 Make sure you have no raytrace materials in the scene. Those will hard crash Vray as well. Does Vray return any errors in the dialog? Link to comment Share on other sites More sharing options...
kwerch Posted February 22, 2007 Author Share Posted February 22, 2007 No luck with the increase in virtual memory- I upped to 4092 and 4092- same crash. There are no raytrace mats in the scene either- The error that results is something in Max, it appears, and not VRAY- Hmmmmmmm. Link to comment Share on other sites More sharing options...
lecameleon Posted February 23, 2007 Share Posted February 23, 2007 >> LMAO... whatever!!!!! and yeah, check for raytrace mats... also, displacement and/or noise/(other procedurals) maps... Link to comment Share on other sites More sharing options...
Mike T Posted February 24, 2007 Share Posted February 24, 2007 You can also try this which deals with 3GB Switch. http://www.cgarchitect.com/vb/21807-help-please.html which will lead you to this: http://technet.microsoft.com/en-us/l...ae443ecbf.aspx Link to comment Share on other sites More sharing options...
