Mental Ray question
skala67
I am working with a final gather map solution, and as I have gone forward the final image has started to deteriorate. (no more anti-aliasing, and blurriness) I have not changed any settings, and have even reset the fg map, but i keep getting less and less quality. (see attached)
Also any tips on how to speed up Mental Ray when it comes to animations would be great. I am using the final gather map solution at a low final gather preset setting.
cheers.
Hi,
AA 1/16 - 16 or 1/4 - 4 or 1 - 4 or 1 - 16 (you need HIGH levels too... your 1 is not enough)
You need more FG bounces (about 5, - I assume you use FG only) or GI with many more bounces (8-12)... (use GI to lower renderingtime!)
Try density 1 / FG 50 / interpolation 100
definately add AO in your materials!
pls post an update with these settings ,-)
rgds,
nisus
