mesht Posted February 23, 2007 Share Posted February 23, 2007 i would like to know if a .max file is compatible in the 64 bit version of Max 9? can i open and save a .max file in a 32-bit version and open in a 64-bit version and vice versa? Link to comment Share on other sites More sharing options...
Watto Posted February 23, 2007 Share Posted February 23, 2007 Hi. This is my first message, and I will answer you. Yes, it's totally compatible both versions. The problem is between versions, from 9 to 8, but from 32-bits to 64-bits and viceversa there's no problem. Be happy, Watto. Link to comment Share on other sites More sharing options...
mesht Posted February 23, 2007 Author Share Posted February 23, 2007 hi watto, thanks for yor reply at least i can work in both versions without worrying about compatibility Link to comment Share on other sites More sharing options...
nisus Posted February 26, 2007 Share Posted February 26, 2007 can i open and save a .max file in a 32-bit version and open in a 64-bit version and vice versa? Yes and no. It doesn't make a difference to open the same file, BUT if you render the file both in 32 and 64bit, the results ARE NOT the same. (The calculation happens another way...) rgds, nisus Link to comment Share on other sites More sharing options...
