skala67 Posted February 24, 2007 Share Posted February 24, 2007 Does anyone know why this is happening and even better, how to fix it? I am using a final gather map which i created with a grey override material. I thought that this was supposed to avoid these artifact problems. Anyone have any ideas on how to fix? It is for an animation so moving the camera is not a solution. Thanks, tj Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 26, 2007 Share Posted February 26, 2007 There is a bug with the fast interpolate reflections. Don't use fast interpolate. Try using a combination of the High detail distance settings and trace depth under the advanced rendering tab. For the walls and ceiling, just use the Highlightsand FG only. No need for glossies there. JHV Link to comment Share on other sites More sharing options...
nisus Posted February 26, 2007 Share Posted February 26, 2007 Just a note: You are talking about using a grey override, but I do see color in your image. Did you check the override checkbox? nisus Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 27, 2007 Share Posted February 27, 2007 I assume you created the FGM with the grey material over-ride then froze the solution, disabled the material over-ride to get the colour back? This will only help in preventing colour bleed and not artifacting. JHV Link to comment Share on other sites More sharing options...
skala67 Posted February 27, 2007 Author Share Posted February 27, 2007 yes, thats what I did, and thats what i learned. I found out the problem. It was because i had used the pearl texture on the walls (A&D material). I changed it to Matte and it worked perfect. It also sped up the rendering process 2-3X. Thanks for all your help. cheers, Link to comment Share on other sites More sharing options...
Justin Hunt Posted February 27, 2007 Share Posted February 27, 2007 I think the Pearl preset uses the fast interpolate Check out Master Zapps blog for more info about these settings and whats really happening http://mentalraytips.blogspot.com/ JHV Link to comment Share on other sites More sharing options...
nisus Posted February 28, 2007 Share Posted February 28, 2007 Yup it does, and that's where the artifacts come from. Be sure to check the max/mr help on how to make 'fake' glossy reflections ;-) rgds, nisus Link to comment Share on other sites More sharing options...
cloaked_spectre Posted February 19, 2008 Share Posted February 19, 2008 thank you, thank you, thank you people!......this was making me nuts......deadlines......again thank you! Link to comment Share on other sites More sharing options...
