geardaddy1 Posted February 26, 2007 Share Posted February 26, 2007 Hi Guys - Creating about 20 animations for a new LRT system. I am starting to get some weird problems with vray. I have attached two renders. In the pink cirlce you can see what is happening....Some frames get "muddy" or more noise than others but only in the shaded areas. There doesn't seem to be any reason that 10 frames out of 800 do this!!! Not sure if you guys can see the problem...it helps to put it in photoshop and switch between the two stills..... I have also attached my render settings. Any help would be greatly appricated. Also, I know there are still "universal settings" for vray. Anyone seen Animation settings? Thanks, Dave Link to comment Share on other sites More sharing options...
Tommy L Posted February 26, 2007 Share Posted February 26, 2007 David, Are you pre-calculating your irradience map? Are you sending this animation to a farm or using only one computer? I would check backburner and see if the ten dodgy frames are all rendered out of the same node, If so, just re-render them on a different pc. Link to comment Share on other sites More sharing options...
dinhtuan Posted February 27, 2007 Share Posted February 27, 2007 David Do your train running? Can't not calculate IR with single mode for render animation. and if the train are moving--> can't use IR maps also. Let try QC+LC for render all sequense or render your static scene with multiframe incremental mode IR+LC and QC+LC only for you moving train. Link to comment Share on other sites More sharing options...
