only3d Posted February 27, 2007 Share Posted February 27, 2007 funny with all the initials no..? lime some secret code only for vray users.. anyways i got a reaccuring problem which i wonder about (and also about to give up LC) when using QMC for 2nd bounce then its all nice & dandy, but sometimes when im using LC for 2nd bounce then everything comes out "bleached".. im talking same scene exactly! i dont know why i insist on trying LC but i know its supposed to give faster results and alittle better even (no?) so any ideas? im using only an ies sun and nothing else on this test, and see what happens.. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted February 27, 2007 Share Posted February 27, 2007 I'm no expert, but I think it looks like you are using only 1 or 2 bounces of light with the quasi montecarlo (qmc) GI. Light cache on the other hand just keeps on bouncing the light around many times. When using an IES sun you should use a logarithmic exposure setting, try it and see if this helps! Link to comment Share on other sites More sharing options...
Stephen Thomas Posted February 27, 2007 Share Posted February 27, 2007 In fact you are probably better using a vray sphere or a simple direct light as your sun. The problem with IES sun comes from the fact that IES or photometric lights use real world intensities and falloff accurately over real distances. That is why it is important to scale your model correctly. As there is no way you can set the IES sun to the correct distance from earth you would normally compensate for this by checking the 'exterior daylight' box in the logarithmic exposure settings. Not sure whether IES sun is best for interior shots though. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 27, 2007 Share Posted February 27, 2007 Not sure whether IES sun is best for interior shots though. Especially when you have VRay Sun to play with... Link to comment Share on other sites More sharing options...
only3d Posted February 27, 2007 Author Share Posted February 27, 2007 tnx 4 the quick replies about the ies sun-i dont think its the cause for the burn, its exactly the same with a standart direct\omni\spot. in fact its the same with no lights at all(!) besides if the sun was so strong it would have burned the QMC shot as well wouldnt it? oh and about the QMC bounce ur correct. -its only 3 bounces but i dont mind that its just as a comparison to the LC engine. about the model- it is modeled correctly. i know it messes up the caculation so i allways model in proper units (cm in this case- 500\500\280) heres another test, plus the vray settings. no lights active Link to comment Share on other sites More sharing options...
only3d Posted February 28, 2007 Author Share Posted February 28, 2007 ideas anyone?.. please this is very frustrating for me and i want to finally undrstand how this works.. Link to comment Share on other sites More sharing options...
alias_marks Posted February 28, 2007 Share Posted February 28, 2007 Can we take a look at your comparable qmc settings and your color mapping settings too? Link to comment Share on other sites More sharing options...
alfienoakes Posted March 1, 2007 Share Posted March 1, 2007 Have you made sure you Viz / max radiosity and environment controls are OFF? It looks like you could be running you Vray settings, along side your Viz settings. Check your advanced lighting tab and environment controls and see if they are on.. Andy Link to comment Share on other sites More sharing options...
only3d Posted March 1, 2007 Author Share Posted March 1, 2007 Can we take a look at your comparable qmc settings and your color mapping settings too? there is no difference what-so-ever in the settings between the 2 shots/ just changed the 2nd bounce engine from QMC to LIGHT CACHE. and theres definitly no radiosity or lightracer active. i tried running vray with a 'skylight' once.. just for kicks.. crashed my max, and then i read in the manuals its a big no no......! Link to comment Share on other sites More sharing options...
rivoli Posted March 1, 2007 Share Posted March 1, 2007 that's really a weird a problem. care to share any of those scenes which you're having troubles with? Link to comment Share on other sites More sharing options...
alfienoakes Posted March 2, 2007 Share Posted March 2, 2007 Do you have your vray default lights turned off..? You could post the scene and let people have a quick look at it..? What version of Viz / vray is it..? Link to comment Share on other sites More sharing options...
only3d Posted March 2, 2007 Author Share Posted March 2, 2007 yep, turned off the default lights.. im posting the scene this time. id be more than happy if anyone wants to get jiggy with it... tnx in advance! Link to comment Share on other sites More sharing options...
dotunmabo Posted January 9, 2009 Share Posted January 9, 2009 im saving the verysame bleaching out probln, and its frustrating. even with no lights , its bleached! ive rendered a shot previously and it was perfect. the next shots just bleach out. any advice? also how do i use the settings in evermotion scenes? do i save the rendersettings as a default, or do i delete their models and replace with my scene, then try to render, or do i have to reset a vray default scene using their settings? any advice onthis will be greatly appreciated , as im just sittin here getting no work done, tryn to figure it out, thanks Link to comment Share on other sites More sharing options...
