reflections blown out
markf
In the image attached you can see that the ceiling and light are being reflected much to bright in the mirror. I tried using a Vray override material. In the overide-reflection material even if I change the diffuse color to red. Rendering remains unchanged.
Any advice on how to correct this?
Thanks in advance for any help.
Timothy,
Thanks for you reply. I tried unchecking affect specular in the modifier panel for the Vray lights. It does fix the reflection problem perfectly.
It unfortunatley removes all of the specular hilights from everything else. I have some chrome faucets and a tub that are hidden in the render I posted above. These and the edge of the counter top all get very dull without thier hilights.
I tried adding an omni with only affect specular checked. It seems to have no affect at all even with multiplier cranked way up. Perhaps because I'm using Vray materials?
I hope I can get this sorted out and move forward.
