mushir_q Posted February 28, 2007 Share Posted February 28, 2007 Hi friends. The thing is that I want to render a scene which contain 160 detailed bungalows on 25 acre land. But the thing is that when i render it max shut down. But when i disable shadows, scene gets render. Whats shud i do? Plz gimme d good solution. I m using AMd 3800 dual core. 2gb corsair ram.Geforce 7600 GT graphic card. Will wait for good solution. Link to comment Share on other sites More sharing options...
BrianKitts Posted February 28, 2007 Share Posted February 28, 2007 have you tried rendering it in partial sections only? what rendering engine/method are you using....scanline...vray...etc??? Link to comment Share on other sites More sharing options...
mushir_q Posted February 28, 2007 Author Share Posted February 28, 2007 I am Using scanling with advance rayraced shadows. Link to comment Share on other sites More sharing options...
AJLynn Posted February 28, 2007 Share Posted February 28, 2007 Have you tried it with the render being saved, but without the on-screen frame buffer? The frame buffer eats RAM. Use Task Manager to monitor your RAM use while rendering. Also, how high is your poly count, and are you making efficient use of instancing? Link to comment Share on other sites More sharing options...
classix Posted March 1, 2007 Share Posted March 1, 2007 If possible it could help to split rendering turning off some houses and combine the imageparts afterwards. Marcus http://www.einherzfuerpixel.de Link to comment Share on other sites More sharing options...
quizzy Posted March 1, 2007 Share Posted March 1, 2007 dont use advanced raytrace, swith to normal raytraced shadows.. Link to comment Share on other sites More sharing options...
