nisus Posted March 1, 2007 Share Posted March 1, 2007 Hi All, I try to render a large image, but I always got 99.99% of the render done when the system hangs. I'm trying to save more memory by adjusting the bitmap pager, but I got no idea how to set it up, meaning I have only this information: http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=5581641&linkID=5573345 I would also like to know whether the setting of the bitmap pager is 'slave'-dependent or 'file'-dependent, meaning: do I have to setup the bitmap pager on a per slave/machine basis? or do I just set it up on my workstation? rgds, nisus Link to comment Share on other sites More sharing options...
martincg Posted March 1, 2007 Share Posted March 1, 2007 Hi, what kind of render do you using? Link to comment Share on other sites More sharing options...
nisus Posted March 1, 2007 Author Share Posted March 1, 2007 MR3.5 (in max9) nisus Link to comment Share on other sites More sharing options...
martincg Posted March 1, 2007 Share Posted March 1, 2007 hm...i am using v-ray so no much help with MR. but sometimes in vray helps, if i am using batchrender /memory saving too/, export it to .bat file, close max and just start directly from .bat file. /sorry for previous Q, did not read the head line/ Link to comment Share on other sites More sharing options...
nisus Posted March 1, 2007 Author Share Posted March 1, 2007 Hi, That's why I use networkrendering. It's a bit the same... /sorry for previous Q, did not read the head line/ don't worry. I edited the title AFTER your Q. I was not specific enough myself ,-) Tnx for pointing that out. rgds, nisus Link to comment Share on other sites More sharing options...
