Guest STU_P Posted March 1, 2007 Share Posted March 1, 2007 Does anyone out there use this particular package? I wasn't sure which forum to go on, so i thought i'd stick it here as it's the most read. Link to comment Share on other sites More sharing options...
Andrew Schroeder Posted March 5, 2007 Share Posted March 5, 2007 Yes, we do. Thinking of buying? Link to comment Share on other sites More sharing options...
Guest STU_P Posted March 6, 2007 Share Posted March 6, 2007 Hi At last i've found someone! We already have it it's just one particular problem we're having and i hope you can help. We're currently producing drawings which are basically a series of blocks joined together by polylines. These items then needed to be connected to a database where numerous items of data are attached to a particular item. We can automatically link the blocks to the database with no problem, however, with the polylines we're having to do it manually. Now in a typical drawing there can be up to 200 lines which as you can imagine is time consuming, especially if you've missed one somewhere. I've created a link template that can pick up on the two blocks either end of the polyline, but the line itself is not a block or text etc. which is required for automatic linking. Is there a way around this? Thanks in advance. Link to comment Share on other sites More sharing options...
