rendering ...error.....help...help...helpppppp
ishhyboy
hai guys...
it have been a long time a having this problem....i couldnt render even in white finishes...first i thought maybe it cause from my material or object but im wrong..i've seen such a detail, heavy and marvelous 3d work....but i wonder why my simple 3d have this problem...INVALID LIGHTMAP SAMPLE...MATERIAL RETURN OVERBRIGHT...and BLA,BLA...
I NEED YOUR HELP GUYS....SOLVE MY NEVER ENDING NIGHTMARE...HUAWAA...
HOPE YOU GUYS CAN FIGURE OUT WHAT MY PROBLEMS....
THANKS...I'LL APPRECIATE WHAT EVER YOUR GUYS DO
:confused:
try making all materials to vray materials and not perfect white and then try...usually the render will come out fine ,even if that error msgs come
..opsss forget to tell...all matt im using vray materials...i;ve change everything from matt,from camera from modeling.....everything...untill im very frustrated....it drive me crazy....
yet i still have that error..sometime only few erro and i still can have my render...but sometime so many error and i couldnt render.....ermmm
any idea...???:(
Hello Kawan,
I had the same problem before I changed to version 1.5. What version are you using?
hello kawannnnn...ermmm ada geng...
im using max 8 and vray 1.47.03
...is that right just change to 1.5???musyikil nie
i am not a professional but this kind of thing happens when u import a model from another 3d software and then you do not apply materials on some of the imported content.....
i suggest that u should selet every item of your model (use your selection tool to make it easier), then make sure u apply materials to them....(NOTE.. if u are using vray renderer then use vray mats)
thanks.... see ya
thanks.... see ya
hahahahah...its funny ya....
im using 100% vray material for your infomation...anyway thanks
