al_farooq Posted March 3, 2007 Share Posted March 3, 2007 hi all, after extrusion my arc changed his shape ,pls see attached file with care and give me soution Link to comment Share on other sites More sharing options...
Brian Smith Posted March 3, 2007 Share Posted March 3, 2007 you say this happened after extrusion? that seems really weird. this typically happens with arc when you import as a AutoCAD dwg file rather than as a legacy file...can you confirm that the change occured only after the extrusion? Link to comment Share on other sites More sharing options...
IHAB Posted March 3, 2007 Share Posted March 3, 2007 hi al-farooq can you send us the original shape of your arch , i mean the spline youre trying to extrude Link to comment Share on other sites More sharing options...
jsf Posted March 3, 2007 Share Posted March 3, 2007 In Max extrusions are usually projected up in the positive Z axis. Is it possible that you drew your spline in a "front" or "side" view, if so draw your spline in the "top" view and then try adding the extrusion. This should give an extrusion that projects 90 degrees from the X & Y axis. Hope that helps. Link to comment Share on other sites More sharing options...
