Black images when rendering pictures on wall?
turbo2000
  • 1 month later...
Hmm.. i have tried to apply the background image to a wall as material but it doesn't shine through?
BTW: I'm using archicad and are rendering via the maxwell plugin. Do i have to change the settings for the material to let the sun shine through it in the maxwell editor?
Are you trying to make the wall glass? Try using one of the Maxwell preset "AGS" materials - they're the only ones that let sunlight go through glass correctly. If you want to have the wall be there, opaque and all, and the sun just go through it as if the wall did not cast shadows... you can't. Maxwell doesn't have the option to turn off shadows for an object.
I am trying to let the sun shine through my wall/image..
I'll try to explain my problem in text here:
HERE IS THE SUN (is in the back)
HERE IS MY WALL/BACKGROUND IMAGE (is in the middle)
HERE IS MY HOUSE (is in front)
The problem is that the wall blocks the sun from shining in to the house :)
Hi i managed to move the wall so far away that it didnt block the sun, but now i have a new problem.. :confused:
Why does it take so long to render this image (its still running) ? http://www.lusica.dk/pic1.jpg
I only use Physical Sky and sun and the resolution is 800x320? My computer is a core duo 2.0ghz with 2gb ram could it be the background image witch is too big?
This image did only take about 5 hours to render (its from outside the same image) i know its a smaller resolution but the other isn't that bigger :S
http://www.lusica.dk/pic2.jpg
Ps: Im using the maxwell plugin to archicad.
