Devin Johnston Posted March 7, 2007 Share Posted March 7, 2007 I'm just getting set up with Vray and I'm trying to get my DR system up and running. I've got a dual processor quad core system so that's 8 processors and I've got another dual processor system that I want to use to do distributed rendering. I've got the vrayspawner90 running on the computer and I have added that machine to my DR list. When I do a test rendering all 8 of my processors begin to render and the DR computer comes in and start rendering. Like I said it's a dual processor and for what ever reason the DR process is only using 1 of the 2 available processors. I read a thread on the Chaos site which said you had to run a max script in order to enable Vray to use multi threaded processors so I run the script which is this (renderers.current.system_numThreads=8) and not only do all 8 of my processors show up as buckets but I get 8 buckets from my render node. This render node is a dual processor AMD Opteron so the maximum number of buckets it should be showing is 2 but I'm showing 8 that actively render. Someone help me out here and tell me what's going on. Link to comment Share on other sites More sharing options...
AJLynn Posted March 7, 2007 Share Posted March 7, 2007 Your Maxscript command forced 8 threads - 8 threads is 8 buckets regardless of the number of CPUs. Usually on a dual CPU you see 2 buckets because the system sees 2 CPUs and defaults to 2 threads, but that bug keeps it from doing that. What you want is to change the 8 to a 2 for the 2-CPU system. I don't know enough about this problem to know whether you can actually do that, but that's what you would want to do if you can Link to comment Share on other sites More sharing options...
