inserting object...
flooatz
guyz i have a difficult time in inserting objects. i work with 3dsmax in my rendering (vray plugins). i model in AutoCAD (scale in mm) then i import it to 3DSmax.
now, i have an object in DFX and MAX form (furnitures). i use merge in inserting object as other says. but the object seems to very small and in wireframe only. how can i view with shades and scale to fit in my model?
hope u can help me guys...:)
the scaling issue is a known problem (well i run in to it often anyways)
its mostly cuz you model in mm and your max units is something else and on top of that maybe your furniture is in inches... so 3 different units from 3 different software is very likely to mess up your scale. still maybe if you change your max units to mm it might help in some way..
about your wireframe issue- is it only in viewport or also in rendering?
it might be just a 'flipped noramals' problem, in that case u can use 'force 2-sided' option in your rendering and viewport conf'.
hope this helps
thanks for the respond bro..
i got it now in the right way it helps alot. the prob is when i import the model from CAD to max i didnt not change the setting to mm hehehe but now the prob already fix, thanks for the help bro...
