flooatz Posted March 12, 2007 Share Posted March 12, 2007 guyz i have a regarding in displaying my curtain in the window. my doors and window are in glass material, behind each glass has a curtain with yellow color(other). my prob is only the left side curtain seem to appear while the front side doesnt display when i render. my model was made in AUtOCAD , i use vray as renderer, even in scanline the curtain in front side was gone. i hope u can help guys..thank in advance Link to comment Share on other sites More sharing options...
Tyorl Posted March 12, 2007 Share Posted March 12, 2007 Check Normals direction of your curtains. Link to comment Share on other sites More sharing options...
flooatz Posted March 15, 2007 Author Share Posted March 15, 2007 where i can find the Check Normals option bro..? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted March 16, 2007 Share Posted March 16, 2007 Make sure your curtain material is a 2 sided material, this way no matter what direction your normal is facing it'll render or enable force 2 sided in the render settings. For checking what direction your normal is facing you can check a checkbox in mesh or poly mode and when you select a face a blue line will be emitted in the direction of the normal. If the line is not heading toward your camera, and you do not have a 2-sided material or have force 2 sided on in the render settings you will not see that object. For more information on normals, see the max help files. Link to comment Share on other sites More sharing options...
flooatz Posted March 16, 2007 Author Share Posted March 16, 2007 thank you guys i will try... jaz a quick question how to know if the its is 2sided or how to make it 2 side material? i model it in autocad, the curtain was made in a rulesufe command.. hope u can help me guyz.. thanks agian.. waiting for ur answer.. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted March 16, 2007 Share Posted March 16, 2007 Assuming you have materials applied to these objects and are not just using vertex color. For Standard materials: It is the in the "Shader Basic Parameters" section. Usually this is the first section of the material. There is a check box labeled "2 sided" make sure that is checked. For Vray materials It is in the "Options" section. Again, there is a check box that says "Double Sided" make sure that is checked. See the max or vray help files for any further information. Link to comment Share on other sites More sharing options...
kippu Posted March 17, 2007 Share Posted March 17, 2007 maybe the glass on the left side is reflecting a lot so that you cannot see your curtains? Link to comment Share on other sites More sharing options...
