al_farooq Posted March 15, 2007 Share Posted March 15, 2007 hi all, i want to use two or three kind paint on one wall for example i modelled a 4*5 meters room walls r three meters high.now i want to use 1st kind paint one meter heigh from floor after that a 10cm moulding and after moulding will b second kind of paint and after that will b cornice moulding.so four kind paint will b on all walls as given below 1-first colour paint from floor till one meter height 2-10cm moulding will b paint by second colour 3-upper part of wall after moulding will b paint by third colour 4-moulding at the edge of ceiling and wall will b painted by fouurt kind of colour pls tell me how i can do in my model by 3ds max Link to comment Share on other sites More sharing options...
classix Posted March 15, 2007 Share Posted March 15, 2007 Hi You can create a blend material with another blend material nested in. Any number of nested materials is possible. You have to create masks for the different materials. Hope that helps Marcus www.einherzfuerpixel.de 3D Rendering, Animation und Architektur-Visualisierung - Aachen Link to comment Share on other sites More sharing options...
raterry Posted March 15, 2007 Share Posted March 15, 2007 The way I'd do it is make sure your walls are editable poly. 1. Select all the walls in sub-object poly mode. 2. Click slice plane and position it at the base of your walls. 3. move the slice plane up 1 meter, click slice. 4. move it up 10 cm, click slice, etc. etc. for all the different paint colors Create a multi sub-object material with a slot for all the diff. colored paints you want and assign them accordingly. Personally I think it's easier than to try to fake the distances using a blend material but at least you have choices.. Good luck. -=Rob Link to comment Share on other sites More sharing options...
GeraldH Posted March 16, 2007 Share Posted March 16, 2007 http://www.cgarchitect.com/upclose/article6_TB.asp ...good luck Link to comment Share on other sites More sharing options...
