JBW77 Posted March 15, 2007 Share Posted March 15, 2007 I can't seem to figure out what I should be putting into the "v-ray license server information" dialog box. In the instruction is says to use the ip address or the server name. I've try both and it still can't find the license. The v-ray license icon shows up in the tray on the server, so it seems as like I have that portion correct. Any help would be greatly appreciated Link to comment Share on other sites More sharing options...
AJLynn Posted March 15, 2007 Share Posted March 15, 2007 See if you can ping the server from the client machine, and make sure there's no firewall software on either machine blocking that connection... Link to comment Share on other sites More sharing options...
JBW77 Posted March 15, 2007 Author Share Posted March 15, 2007 It ping just fine. It seems like it should work since this is the same server where all of my software licenses are located. (ADT, VIz) Is there any thing to the connection port. Are you supposed to just keep their default 30304 numbers there? I didn't see anything about it. Except for if you were running the license on your local machine. Link to comment Share on other sites More sharing options...
AJLynn Posted March 15, 2007 Share Posted March 15, 2007 I don't see why you'd have to change the port. According to IANA 30304 is unassigned so it's unlikely that there's a conflict. Did you try on the Chaosgroup site? Link to comment Share on other sites More sharing options...
JBW77 Posted March 15, 2007 Author Share Posted March 15, 2007 Yeah that’s what I tried first. Doesn’t appear to be clear, or I’m just not to smart. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted March 15, 2007 Share Posted March 15, 2007 try looking in \Program Files\Common Files\ChaosGroup in the INI file and make sure your key is actually written there. Just this week I had the same problem and for some reason the key was not being recognized. I ended up just copying and pasting it over the one listed in the server dialog and it seemed to have taken then. Link to comment Share on other sites More sharing options...
JBW77 Posted March 16, 2007 Author Share Posted March 16, 2007 I check the VRFLServer.ini the key appears to be correct. But just for the fun of it I also re-pasted it. It still says, "could not obtain a License" Link to comment Share on other sites More sharing options...
AJLynn Posted March 16, 2007 Share Posted March 16, 2007 This does sound like the kind of thing where Chaosgroup can give you more useful support than we can, have you contacted them? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted March 17, 2007 Share Posted March 17, 2007 I agree with Andrew... I would contact chaos via their forum or direct email. Link to comment Share on other sites More sharing options...
