nilariver@gmail.com Posted March 19, 2007 Share Posted March 19, 2007 While rendering with v ray i am not getting outstanding glass and stainless steel can anybody can help me to get good steel and glass Link to comment Share on other sites More sharing options...
sterealkey Posted March 19, 2007 Share Posted March 19, 2007 What I usually do when I struggle with a material is to download it and then analyse how it was done, you will learn a lot of cool techniques this way. go to vray-materials.de You will find most common materials there, but try not to use them, instead try to recreate them, otherwise you will get lazy. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 19, 2007 Share Posted March 19, 2007 i spent time last week struggling with a decent brushed stainless. this is what i wound up using for the project... not perfect, but you are welcome to using it. i wound up using a image map for the brushed part. i know it is possible to create the brush with procedural textures, i did it with a map because i had a map available. i think the glass i included originated from the website above. maybe a few tweaks, i can't remember. i think it was called CrystalGlass. ts. Link to comment Share on other sites More sharing options...
kippu Posted March 19, 2007 Share Posted March 19, 2007 stainless and glass depend much on the environment you work on...so take care of that Link to comment Share on other sites More sharing options...
redzuan3828 Posted March 20, 2007 Share Posted March 20, 2007 why not you look this tutorial. It give nice glass, water and crome setting that look find to me and i will use it in the future project use falloff and resnel thanks to Paco Morales from Mexico for spending his time to create this tutorial, God bless you http://www.cgarena.com/freestuff/tutorials/max/hdri-vray/index.html this what i have done with this tutorial You can see the glass the water and steel (crome) Link to comment Share on other sites More sharing options...
stormchaser Posted March 21, 2007 Share Posted March 21, 2007 can you post a picture of the result youre getting? and give soem idea abt your scene setup. like kippu said its about environment most of the time. Link to comment Share on other sites More sharing options...
redzuan3828 Posted March 22, 2007 Share Posted March 22, 2007 While rendering with v ray i am not getting outstanding glass and stainless steel can anybody can help me to get good steel and glass i don't no is this the good glass that you ask? i'm using hdri as background and reflection. i'm follow this tutorial for material glass and crome http://www.cgarena.com/freestuff/tutorials/max/hdri-vray/index3.html You can see my test render hope this will help:) redzuan Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted March 23, 2007 Share Posted March 23, 2007 Can I prolongue this discussion for a while and call for other people to give examples of success they've had with rendering brushed, satin or hairline finish steel? I get many projects from HK where they just want to upgrade the common areas etc and I've often had to produce this kind of effect. Up to now I've just been using blury metal with a map rather like the one used above and some ansitropy. Anyone got some more ideas? Link to comment Share on other sites More sharing options...
redzuan3828 Posted March 23, 2007 Share Posted March 23, 2007 anybody can help me to get good steel and glass Today I got bundle vray material at this link. http://www.evermotion.org/index.php?unfold=download&showdownload=yes Its has different type of glass, aluminium, chrome. the good thing is it come with mat file I don't no that material good or not but You can learn from it.... or somebody can comment on it......at least we can share knowleage redzuan Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted March 23, 2007 Share Posted March 23, 2007 Thanks Link to comment Share on other sites More sharing options...
jtmdr Posted March 24, 2007 Share Posted March 24, 2007 A confession... About a year ago I became obsessed (somewhat crazily) about how to do "proper" stainless steel. Gurrr...... The best sample(s) I could come up with are here. Several things I learned: Stainless is entirely dependent on scene lighting. These images are all done with the SAME bump map created in Photoshop (pshop/ blur) and then applied to each item in a different fashion. (varying amounts amounts of bump map mostly) there are only two lights in this scene (omni & spot). I'd intended to do a tutorial on this but never finished - it became long. If you still have any interest, I'll forward (maybe complete) the tutorial. I did learn that "proper" stainless can slow a render to a crawl. Perfect everything else in the scene, then start toying with the stainless. There are some other great samples on this board, but this is what I was able to come up with. Link to comment Share on other sites More sharing options...
keeka Posted March 24, 2007 Share Posted March 24, 2007 This tutorial is for 3ds Max but it might help you out! http://www.cgarchitect.com/resources/tutorials/smoke3d/tutorial5.asp Link to comment Share on other sites More sharing options...
