martin walker Posted March 20, 2007 Share Posted March 20, 2007 Is there a way of speeding up rendering of alpha channels in v-ray...any cheap / dirty tricks to quicken things up ? thanks in advance Link to comment Share on other sites More sharing options...
BrianKitts Posted March 20, 2007 Share Posted March 20, 2007 your alpha shouldn't slow down your render at all.... just use the render elements to save out the alpha in addition to your actual render. On the other hand if you are referring to going to a scene and just rendering out the alpha only, you could use the material over-ride and make everything a simple plain material color with no reflections. (as long as you don't see the alpha through glass... in which case you can't use just the over-ride). could turn off GI as well to speed it up what exactly is it you are trying to do? Link to comment Share on other sites More sharing options...
martin walker Posted March 20, 2007 Author Share Posted March 20, 2007 im using forest pro to create foliage (bill boards) Link to comment Share on other sites More sharing options...
Chad Warner Posted March 21, 2007 Share Posted March 21, 2007 Make sure you are using vray materials. Also, set the blurring in the bitmap to .001 and the bitmap filtering to none. That should help speed things up. Link to comment Share on other sites More sharing options...
martin walker Posted March 21, 2007 Author Share Posted March 21, 2007 thanks Chad I presume I do this in both opacity and diffuse channels ? I'll let you know how I get on Link to comment Share on other sites More sharing options...
Chad Warner Posted March 21, 2007 Share Posted March 21, 2007 Yes. Link to comment Share on other sites More sharing options...
