justintime1 Posted March 22, 2007 Share Posted March 22, 2007 Texture Mapping help!> Hi folks. I’m trying to create the edge of a lake for on of my models, I have created a blend material to give the impression of the grass fading to the lakes edge. Please see image. It maps fine to a plane or a box but I was wondering how I might get it to map to a random shaped mesh such as the one that is also in the image, Any suggestions would be greatly appreciated, Many thanks Mat. Link to comment Share on other sites More sharing options...
Sawyer Posted March 22, 2007 Share Posted March 22, 2007 Real fun stuff like this works best with the UNWRAP UVW tools. You could look around for a good tutorial on using them but the idea is you get your mesh and make a jpg out of the mesh with the mesh laying flat or unwrapping like a shell then you take it into ps and paint ontop of that. Then when you apply the material it fits on the mesh. There is also the camera per pixel option. That is really fun but you get into trouble if you have to move your camera at all. basical you render, then you paint onto the rendering, then you add that painted rendering as a material. I used it once when I had a terrible deadline. The deadline was met and the designer like it so much he wanted me to redo the scene with a different view. All textures were view dependant and useless. Link to comment Share on other sites More sharing options...
justintime1 Posted March 22, 2007 Author Share Posted March 22, 2007 Cheers for the advice but I need to be able to animate the scene... Rubbish. Something tells me this isn’t going to be easy Thanks for your suggestion tho. Link to comment Share on other sites More sharing options...
Sawyer Posted March 22, 2007 Share Posted March 22, 2007 Just use the UVW UNWRAP tools they will do what you want. Link to comment Share on other sites More sharing options...
justintime1 Posted March 22, 2007 Author Share Posted March 22, 2007 cool il give it a go. cheers.. MAtt. Link to comment Share on other sites More sharing options...
BrianKitts Posted March 22, 2007 Share Posted March 22, 2007 depending on how precise you are trying to be, you could apply the mapping to the object and then edit the mesh after the mapping is applied and your texture will follow suit..... Link to comment Share on other sites More sharing options...
