how to create this curtain wall or wall
taylor77
I have no idea how to do it in Revit - this is how I would do it in max.
I wouldn't bother with a nurbs surface though. The way I described will give you polys where you need them.
The spline you use to create the shape needn't be circular, it just has to have paralell lines running across it, then you select one half of the outer edges and position them as required. It's actually a very simple shape, two curves, segmented lengthways, offset and then split horizontally.
