jcsDesigns Posted March 23, 2007 Share Posted March 23, 2007 Hi All I have been getting a WARNING! when I render my model in Vary its says the following:- Performance loss, the number of rendering threads (8) is greater than the number of light cache (4), some threads will be lost!! could any one tell me what this means?? Thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted March 23, 2007 Share Posted March 23, 2007 in your light cache settings..... set the number of lightcache passes equal to the number of processors you have in your system. Link to comment Share on other sites More sharing options...
jcsDesigns Posted March 23, 2007 Author Share Posted March 23, 2007 I have a 2 quad core xean processor with 4gb of ram... so that waould mean I should change it to 8 yes! will this seep it up? Many thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted March 23, 2007 Share Posted March 23, 2007 if you get 8 buckets when you render you should set it to 8. You might notice a speed difference if you time it, but it probably won't be something that you outright notice and fall off your chair. Link to comment Share on other sites More sharing options...
jcsDesigns Posted March 23, 2007 Author Share Posted March 23, 2007 I now have a message saying Raytracer Out Of Memory?? There isn't enough memory for the raytracer to build its acceleration data structures? Wot does this mean. Sorry to keep bothering you. Link to comment Share on other sites More sharing options...
BrianKitts Posted March 23, 2007 Share Posted March 23, 2007 pretty much what it says....you are running out of memory... check out this thread.... the second error discussed (not the first one) is what you are running into and then some solutions are given. http://www.cgarchitect.com/vb/21458-whats-causing-error.html Link to comment Share on other sites More sharing options...
