malayali Posted March 26, 2007 Share Posted March 26, 2007 In 3ds max, when I was doing more than one Boolean operation to an object, some sides of the subtracted portions not visible. If I apply cap hole modifier then the whole subtracted area will fill. How can I solve this problem? The same problem is happening when applying more than one slice modifier to an object. Link to comment Share on other sites More sharing options...
bborne Posted March 26, 2007 Share Posted March 26, 2007 IMO Boolean operations are a nice way to crash your 3dsmax. heh. But if you really need to work with them, try to collapse the mesh between each boolean operation. Check if you don´t have any strange edges or loose vertices and go on. [EDIT] You should try to seach the formus for "boolean" threads, you will find some good info: http://www.cgarchitect.com/vb/22713-boolean-problem-yea-i-know.html + Bruno Borne Link to comment Share on other sites More sharing options...
