Jeffrey Posted March 27, 2007 Share Posted March 27, 2007 I use the terrain in 3d to create this landscape but I'm not too happy about the result. Still a lot of small adjustment I need to do but it doesn't give me too much control. Is there any better to create a terrian with lots of control. Cheers. Link to comment Share on other sites More sharing options...
AJLynn Posted March 27, 2007 Share Posted March 27, 2007 You could look at the sections on sites here: http://www.cgarchitect.com/upclose/VI/default.asp But if I were doing it I'd decide the geometry's good enough, work on the material maps for the terrain and make a more realistic base on the part on the right. Link to comment Share on other sites More sharing options...
Jeffrey Posted March 27, 2007 Author Share Posted March 27, 2007 You could look at the sections on sites here: http://www.cgarchitect.com/upclose/VI/default.asp But if I were doing it I'd decide the geometry's good enough, work on the material maps for the terrain and make a more realistic base on the part on the right. I have the contour line from autocad but it's not totally accurate. What I mean is I still need to make a lot of changes on the terrain. What is the easier way to give me the maximum flexibility? Link to comment Share on other sites More sharing options...
Ky Lane Posted March 27, 2007 Share Posted March 27, 2007 Ive done this before and found just setting up a plane with lots of divs, converting to a poly then moving the individual points with a soft selection was best. Link to comment Share on other sites More sharing options...
mahorela Posted March 27, 2007 Share Posted March 27, 2007 I may be missing something but what happened to creating a plane with lots of polygons and then painting yourself a terrain map in photoshop and using it in conjunction with a displacement modifier? Link to comment Share on other sites More sharing options...
Jeffrey Posted March 27, 2007 Author Share Posted March 27, 2007 Ive done this before and found just setting up a plane with lots of divs, converting to a poly then moving the individual points with a soft selection was best. what if I'm building something like this? isn't that gonna take ages to build? Link to comment Share on other sites More sharing options...
Ky Lane Posted March 27, 2007 Share Posted March 27, 2007 what if I'm building something like this? isn't that gonna take ages to build? No not really....just set up your contours as guides, and just pull up the points to meet the contours...gives you the ability to move individual points around to suit the scene more, quickslice the plane to get more accurate shapes or nurb it to smooth it out. One way I did it, was scan the countour map, place it on a plane under the landscape plane, and either going by the divs, or using a quickslice, Id just grab the points which intersect a contour, and just type in the Z value and pop...there you go! If you got the contours there as a max file, shoot em over and Ill see what I can do up for you. Link to comment Share on other sites More sharing options...
Jeffrey Posted March 27, 2007 Author Share Posted March 27, 2007 I may be missing something but what happened to creating a plane with lots of polygons and then painting yourself a terrain map in photoshop and using it in conjunction with a displacement modifier? how come I didn't think of this? stupid me.. I'll give it a try. Thanks.. Just one question. because I also need to add displacement for grass too, can I apply displacement twice? Link to comment Share on other sites More sharing options...
Jeffrey Posted March 27, 2007 Author Share Posted March 27, 2007 No not really....just set up your contours as guides, and just pull up the points to meet the contours...gives you the ability to move individual points around to suit the scene more, quickslice the plane to get more accurate shapes or nurb it to smooth it out. okay. I can do that.. will give it a try. Cheers Link to comment Share on other sites More sharing options...
mahorela Posted March 27, 2007 Share Posted March 27, 2007 how come I didn't think of this? stupid me.. I'll give it a try. Thanks.. Just one question. because I also need to add displacement for grass too, can I apply displacement twice? just use standard displacement for the terrain and vray displacement for the grass....should be ok. Link to comment Share on other sites More sharing options...
Gene Posted March 27, 2007 Share Posted March 27, 2007 What do you guys think of setting up some splines which represent the individual loft lines of the surface/terrain and then turn it into a NURBS surface? I found the surfaces are really smooth although perhaps not as accurate as a triangulated mesh. I am still pretty new here so I don't know if there is a downside? Link to comment Share on other sites More sharing options...
AJLynn Posted March 27, 2007 Share Posted March 27, 2007 I don't see any reason not to if you're getting a good result. Link to comment Share on other sites More sharing options...
stormchaser Posted March 27, 2007 Share Posted March 27, 2007 your grass in the first view looks great. any chance of sharing your secret? btw i tried making terrain before and its never easy. my friend uses maya and he finds it relatively easy to make terrain by drawing curves on nurb surface Link to comment Share on other sites More sharing options...
Jeffrey Posted April 17, 2007 Author Share Posted April 17, 2007 your grass in the first view looks great. any chance of sharing your secret? btw i tried making terrain before and its never easy. my friend uses maya and he finds it relatively easy to make terrain by drawing curves on nurb surface thanks. I'm using 2D displacement. Link to comment Share on other sites More sharing options...
