Asim Harbas Posted July 5, 2002 Share Posted July 5, 2002 Rhino and Lightscape Link to comment Share on other sites More sharing options...
nisus Posted July 6, 2002 Share Posted July 6, 2002 Hi asim, Well done. A few critics though: - I was wondering where the light streakes come from? - The wall and the ceiling don't seem to intersect because you got lot's of shadows on the walls, and hardly any on the ceiling. rgds nisus Link to comment Share on other sites More sharing options...
Jeff Mottle Posted July 8, 2002 Share Posted July 8, 2002 Originally posted by nisus: - I was wondering where the light streakes come from? Nisus is right. Do you have lighting on the other side of the walls? As I suspect you do, you are getting light leaks. You need to make sure that your walls are made of two faces not a single two sided face. Also you need to break the ceiling at the walls rather than exteding it from room to room. Link to comment Share on other sites More sharing options...
Cesar R Posted July 8, 2002 Share Posted July 8, 2002 Jeff can you exaplain what you just said in a visual way please ? Link to comment Share on other sites More sharing options...
STRAT Posted July 8, 2002 Share Posted July 8, 2002 i dont think he's done what jeff said. i think he's modelled up just the one room and those streaks are a half hearted stab at adding spots or down lighters all along the walls. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted July 9, 2002 Share Posted July 9, 2002 Originally posted by Cesar Rullier: Jeff can you exaplain what you just said in a visual way please ?Hey Cesar, See if this helps any: http://www.discreet.com/support/lightscape/faq/answer.php3?prod=lightscape&id=445 http://www.discreet.com/support/lightscape/faq/answer.php3?prod=lightscape&id=535 Link to comment Share on other sites More sharing options...
John Dollus Posted July 10, 2002 Share Posted July 10, 2002 It appears as though there are light sources other than the ceiling mounted ones visible in the image. The streaks on the wall and the bright interior corners seem to be from lights beyond the room or surfaces not meeting at an intersection (or both). Try rendering an image with raytracing and activating the 'raytrace direct illumination' in the luminaire processing options. John D Link to comment Share on other sites More sharing options...
Cesar R Posted July 10, 2002 Share Posted July 10, 2002 thanks Jeff Link to comment Share on other sites More sharing options...
Cesar R Posted July 11, 2002 Share Posted July 11, 2002 Jeff, is learning Ls really worth it when you have renderers like brazil and FR ? anyway, where can I get the LS tutorials metioned in the links you sent me ? (FAQ) Link to comment Share on other sites More sharing options...
bigcahunak Posted July 11, 2002 Share Posted July 11, 2002 All LS tuts are in the Lightscape folder (where you installed it) as a pdf file. Link to comment Share on other sites More sharing options...
STRAT Posted July 11, 2002 Share Posted July 11, 2002 cesar - LS may not be the most intuetive and easiest to learn, but it does do the most realistic radiosity rendering on the market. leaves brazil and FR standing still. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted July 11, 2002 Share Posted July 11, 2002 Well I can't speak from experience as I've not had the time or oppourtunity to benchmark all of the GI renderers out there against each other, but STRAT is correct in that Lightscape still does it the best. It has its limitataions, and aps like brazil do pick up where Lightscape leaves off, but for the most part I am hearing that Lightscape is still king of the hill. In regards to the tutorials, they are on the CD that Lightscape is on. You do have the CD...right Jeff Link to comment Share on other sites More sharing options...
Cesar R Posted July 11, 2002 Share Posted July 11, 2002 ...not anymore ? Link to comment Share on other sites More sharing options...
