how can I make concret in vray (3dmax 9)
gabrielvalencia
i recommend using a nice bitmap in just the bump channel. you certainly can use a bitmap in the diffuse channel but changing the color of the concrete means changing the bitmap, which can be time-consuming, especially if you're trying to show a client (in-person) change after change.
I can go with that, concrete when it is mixed is usually a pretty uniform color - however it changes pretty quickly over time giving it a less uniform apperance. Would you consider doing a vray dirt pass for compositing later?
Also do you know any good tutorials for vray dirt as I haven't been able to get very interesting effects with it up to now?
