andreg Posted March 30, 2007 Share Posted March 30, 2007 Hi all, I've been having this problem ever since I got v-ray and never been able to fix it. When I render a scene locally on my workstation everyting renders fine but when I use DR, I always get either a black bucket or the v-ray window can't find the dll on the render node. I have checked and the dlls are all there in the plugins folder on the render node. When I render v-ray lights or anything else, DR works fine. I've been starting to use these (sun/sky/cam) alot since they are so amazingly easy to work with but then I'm able to render on only my workstation. This is a big problem because it takes longer to render my scenes using only one computer. I'm using a Boxx workstation (2x dual opteron 285) and one render node (Boxx also) with XP pro, max8SP3 and v-ray1.5-RC3. We are looking to buy more nodes from them and I want to fix this issue before we get more machines. If you need more info or more specs just let me know. Note: I also posted this on v-ray forum, hpoe you guys don't mind Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted March 30, 2007 Share Posted March 30, 2007 I'm curious... are you using V-Ray's DR or Backburner? Link to comment Share on other sites More sharing options...
andreg Posted March 30, 2007 Author Share Posted March 30, 2007 I use a bit of both depending on the situation. Why do you ask? Is it better one way versus the other? btw Thanks for replying Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted March 30, 2007 Share Posted March 30, 2007 Not sure which one would be better... it's just that some people say V-Ray's DR is a bit unstable. Does the same thing happen using both? Link to comment Share on other sites More sharing options...
andreg Posted March 30, 2007 Author Share Posted March 30, 2007 yes. Edit: I solved my problem... The plugin.ini file was loading the v-ray plugins before the max plugins on the render node Link to comment Share on other sites More sharing options...
jeandelessard Posted April 3, 2007 Share Posted April 3, 2007 seems that you have a great sytem in your company André. Link to comment Share on other sites More sharing options...
andreg Posted April 3, 2007 Author Share Posted April 3, 2007 Thank you Jean, I am very happy with my system but we need more power!!! On fourni pas! Link to comment Share on other sites More sharing options...
lindsaylou4 Posted June 10, 2009 Share Posted June 10, 2009 I see this is an older post-- but can someone tell me where exactly i need to change this line of code? I seem to have the same problem and am missing the vray sun and vray camera options all together! I want to uninstall and reinstall, then change the lines of code to make it work. Anyone know? Link to comment Share on other sites More sharing options...
