Macpod Posted March 30, 2007 Share Posted March 30, 2007 I remember reading somewhere that the second hdd can be used to speed up things in photoshop. had something to do with memory i believe. Anyone know how to do it? My fonts are 'appearing' abit slow and i actually had a couple 'not enough memory' msgs on my 2gb DDR2 667 machine.. Thanks Yihang Link to comment Share on other sites More sharing options...
Sindala Posted March 30, 2007 Share Posted March 30, 2007 Yup, Go to Edit > preferences > Plug-Ins & Scratch Disks and select a disk with a lot of free space as first disk. then a second third etc depending on how many you have. i believe PS uses about 4 times as much disk space as the file is big and if you don;t specify it will use C: Link to comment Share on other sites More sharing options...
raynce Posted June 12, 2007 Share Posted June 12, 2007 thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted June 12, 2007 Share Posted June 12, 2007 extra note: if you are in CS3 they have changed the tab, it's no longer under "plug-ins and scratch discs" there's a new section called "performance" If I remember correctly from previous versions, they basically combined the last two options (scratchdiscs & memory usage) into one tab. Link to comment Share on other sites More sharing options...
Matt McDonald Posted June 12, 2007 Share Posted June 12, 2007 The Photoshop scratch disc needs to be moved to a different physical disk than your Windows pagefile. Moving it to a different partition will do you no good. How many fonts do you have installed? A lot? Adobe will tell you that uninstalling fonts that you do not use is a good way to speed things up. Also, cut down on the number of history states. Lastly, you can increase the percentage of system RAM available to Photoshop. Link to comment Share on other sites More sharing options...
