archkre Posted March 30, 2007 Share Posted March 30, 2007 What is the best way to navigate 3DSMax 9 while one is modeling? I mean to orbit around a solid very smoothly " a la Maya" Using shift + wheel the model jumps to hell and does not allow little adjustments! Typing III [[[ ]]] is complicated! Am I missing anything? Thanks Link to comment Share on other sites More sharing options...
archkre Posted March 31, 2007 Author Share Posted March 31, 2007 I tried Arc Rotate SubObject. If it is going too fast, holding down the Alt key. Using Alt with Shift+mouse wheel to zoom will slow down the zoom as well. Ctrl + Alt+ wheel didn't work transparently either! Link to comment Share on other sites More sharing options...
machmirdenlukas Posted March 31, 2007 Share Posted March 31, 2007 same question: i know there`s a plugin that allows navigating in max like in maya. (alt + left button, etc..) could anyone give advice? cheers Link to comment Share on other sites More sharing options...
archkre Posted March 31, 2007 Author Share Posted March 31, 2007 same question: i know there`s a plugin that allows navigating in max like in maya. (alt + left button, etc..) could anyone give advice? cheers It is dRaster "Switcher", but I think 3dsmax9 is expensive enough so as not to invest more money to navigate on screen!!! Link to comment Share on other sites More sharing options...
angelo Posted March 31, 2007 Share Posted March 31, 2007 I've been using the new entry level 3D Connexion's 3D controller called SpaceNavigator. It provides a nice control panel, and the personal edition is 50 bucks or so! Very, very intuitive navigation, and also gives you more time to *work* with the mouse rather than navigate. Angelo Link to comment Share on other sites More sharing options...
machmirdenlukas Posted April 4, 2007 Share Posted April 4, 2007 It is dRaster "Switcher", but I think 3dsmax9 is expensive enough so as not to invest more money to navigate on screen!!! Thanks! Link to comment Share on other sites More sharing options...
AJLynn Posted April 4, 2007 Share Posted April 4, 2007 I like using the scroll wheel for almost everything - wheel for zoom, hold down and drag for pan, Alt-hold down and drag for orbit. Once things get complicated I'll also start using target cameras to look at hard-to-get-at places. Link to comment Share on other sites More sharing options...
ericbarlow21 Posted April 5, 2007 Share Posted April 5, 2007 hold control + alt + hold in mouse wheel then push mouse fowards or backwards for a smooth zoom in/out alt + hold down mouse wheel = orbit around (in the lower right corner of max, there is an icon which can change which you are rotating around - i keep mine on the yellow icon) I use "z" a LOT to zoom into the object/face/etc i currently have selected and it centers the camera these hotkeys i use most to navigate... and then the W E R for move/rotate/scale hope this helps! Link to comment Share on other sites More sharing options...
Nic H Posted April 5, 2007 Share Posted April 5, 2007 hmm I find navigating in max very easy and intuitive. I use scroll wheel for everything, sometimes use walk through mode when detailing internals. Using alt w isolate on most objects. What does maya do that max doesnt navigation wise? Link to comment Share on other sites More sharing options...
