anindia Posted April 3, 2007 Share Posted April 3, 2007 i am just learning this software.can anyone suggest me to produce higher resolution outputs? please i need suggestions. Link to comment Share on other sites More sharing options...
anindia Posted April 3, 2007 Author Share Posted April 3, 2007 Dear Cruz, it's sketchup 6. Link to comment Share on other sites More sharing options...
BrianKitts Posted April 3, 2007 Share Posted April 3, 2007 from the file menu select file->export->2d graphic. Click the OPTIONS tab. Uncheck the "use view size" and change the image height and width to as large as you'd like and save out your file. Link to comment Share on other sites More sharing options...
classix Posted April 3, 2007 Share Posted April 3, 2007 As far as I know there is no possibility to adjust the line thickness with high resolution sketchup images. Marcus Krott www.einherzfuerpixel.de Link to comment Share on other sites More sharing options...
bytor Posted April 3, 2007 Share Posted April 3, 2007 Hello, It is hard to tell exactly from the question - but if you strictly looking for higher than screen resolution images, you will need the professional version. If you want lineweights, etc. - then look into the "Styles" inside of SU6. Bytor Link to comment Share on other sites More sharing options...
anindia Posted April 4, 2007 Author Share Posted April 4, 2007 Thanks, freinds for ur suggestions. i have done it. Link to comment Share on other sites More sharing options...
deevee84 Posted April 5, 2007 Share Posted April 5, 2007 no wonder... i need the pro version to do this ! thanks always wondered Link to comment Share on other sites More sharing options...
Onzki Posted May 4, 2007 Share Posted May 4, 2007 Dear anindia, r u referring to image size/quality(dpi)? well, u can try exporting to 2D (jpeg), then you can use 3rd party programs like Photoshop to reproduce it to a high-res image & make other adjustments. Link to comment Share on other sites More sharing options...
