kwerch Posted April 6, 2007 Share Posted April 6, 2007 I'm trying a very simple animation-A camera flying around an object. When I save the individual bitmaps to file I am getting the image saved without the gama correction applied. How can I save these images from the frame buffer? thx. Karl Link to comment Share on other sites More sharing options...
mfured20 Posted April 6, 2007 Share Posted April 6, 2007 when you go to save your image type, there is a gamma setting underneath the file dropdown box. you can either set it to use the system default gamma [which can be changed under customized>preferences>gamma&LUT], or you can manually control it per image with the override function. good luck! Link to comment Share on other sites More sharing options...
