VitaSky Posted April 8, 2007 Share Posted April 8, 2007 Hi - This is my first time using this forum - my professor told our class to use it. I'm a complete newbie at architecture, and am modeling Villa Savoye by Le Corbusier in AutoCAD. I'm trying to figure out how to model the ramp and the staircase, and it is going slowly and nowhere. I tried to look at it in Viz, but Viz is really confusing and not helping too much, since I don't know it all that well. Any help would be superly appreciated! thanks- Link to comment Share on other sites More sharing options...
Ukamti Posted April 8, 2007 Share Posted April 8, 2007 Hi there, villa savoye is not much difficult to make if you use 3d Max try to use loft for the ramp or customized polgonedit tools and for railing you can use renderable splines. see you later and Shubh ratri (Good Night)! Link to comment Share on other sites More sharing options...
neko Posted April 9, 2007 Share Posted April 9, 2007 that's funny - i was going to have my class model that building this year, but i find the barcelona pavilion is a bit easier for beginners. i think with experience you will learn there is always more than one way to model things. in this situation and with your skill set, i would concentrate on extruding solids (whether in plan or in section/elevation). the staircase has curved treads, correct ? if you can create closed polylines around the boundaries of each tread in plan, it shouldn't be difficult to crate solids from these and move them in the Z axis (eg. 7",14",21"....). if you have autocad 2007, the new PRESSPULL feature for creating solids would make this task easier. as far as the ramp goes, i think it is two long straight flights. if you have a section through it, i would use the same process (extruding solids) but now you would be extruding the width of the ramp (in section). i hope some of this makes sense. you could also use 3D faces for the ramp, if you have the floor slabs and landing defined, but with faces you have no real thickness, just planar surfaces. best of luck paul Link to comment Share on other sites More sharing options...
Jim Kessler Posted April 10, 2007 Share Posted April 10, 2007 Not to be a cheat or anything but.... http://sketchup.google.com/3dwarehouse/details?mid=e5bf9ca29a31327397ff18398e9699a8 http://sketchup.google.com/3dwarehouse/details?mid=e219d7fb67498628433d5325e58d2b99 http://sketchup.google.com/3dwarehouse/details?mid=a9b1831a73fae7e9b776e87569147d79 Link to comment Share on other sites More sharing options...
mskin Posted April 11, 2007 Share Posted April 11, 2007 vita, where are you going to school? Link to comment Share on other sites More sharing options...
IHAB Posted April 11, 2007 Share Posted April 11, 2007 you can do it in straight easy way (asumming that you're fully modeling it) -a box+scale copying inwards (to give walls thickness). -converting this box to an editable mesh & go on +ve,-ve extruding to do windows. -the cylindrical coloumns (I wont tell you ) -as for the inner staircase you can use the standerds of max or viz & some FDD4X4X4 , youre done. more interior details ? Link to comment Share on other sites More sharing options...
vizwhiz Posted April 12, 2007 Share Posted April 12, 2007 Vita which version of autocad are you using? what are you working from? plans and elevations? i might be able To give you some help and/or ideas could you possibly send me a copy of The floor plan? or whatever you are working with i've got about 40,000 hours doing autocad, but not Too much free Time at The moment do you use The UCS? are you working with solids? Thanks Randy Link to comment Share on other sites More sharing options...
kecolano Posted September 29, 2009 Share Posted September 29, 2009 Hi, trying to get a 3d model. Link to comment Share on other sites More sharing options...
