SEIF Posted May 30, 2003 Share Posted May 30, 2003 hiii fellows.. well,it's quite embaressing to post my image while seenig that excellent work over here.. ..so feel free to say what u like.. modelled in AutoCAD using surfaces (except furniture ofcourse) and rendered in lightscape..wizard set to 4.. so hoping for ur help.. Cheers, Mohammed Link to comment Share on other sites More sharing options...
SEIF Posted May 31, 2003 Author Share Posted May 31, 2003 hey fellows..is the image that bad !!!..LOL.. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted May 31, 2003 Share Posted May 31, 2003 so far so good... What do you need help with? Link to comment Share on other sites More sharing options...
SEIF Posted May 31, 2003 Author Share Posted May 31, 2003 well..the main issue that iam testing sun light..so i wanted openions about how it looks..how to improve it..any faults i did'nt observe...etc. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted May 31, 2003 Share Posted May 31, 2003 Well, as you can see, the light is burning your textures. Desaturate them a little. The wall to the right has no secondary light. How long did you run the solution? Why not have the sun coming in angled towards the furniture instead of away from it? That will get more shadow/light playing in the picture. Then crop off some foreground. Link to comment Share on other sites More sharing options...
SEIF Posted May 31, 2003 Author Share Posted May 31, 2003 thx for replying Ernest..the solution didnt take long,just a few minutes i guess.. i'll do the changes u suggested and will post an update as soon as i finish them. thx again. Cheers, Mohammed Link to comment Share on other sites More sharing options...
Jefferson Grigsby Posted May 31, 2003 Share Posted May 31, 2003 How long did you let the solution run? I am not seeing any color bleed or detail to the solution for that matter. Link to comment Share on other sites More sharing options...
SEIF Posted June 1, 2003 Author Share Posted June 1, 2003 The first image's solution stopped after nearly 68%.. i tried to change the sun angle as Ernest suggested in a second trial but the solution also stopped at 73%..what can i do to make it continue??? Link to comment Share on other sites More sharing options...
SEIF Posted June 1, 2003 Author Share Posted June 1, 2003 here's an update..still " glowy " textures even after modifying their values.. the procss stopped at 73%.. so any ideas about what's going wrong?? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted June 1, 2003 Share Posted June 1, 2003 much better. The textures could still use desaturating, and the obvious dark opening, but the room is much improved. Link to comment Share on other sites More sharing options...
xgarcia Posted June 1, 2003 Share Posted June 1, 2003 If you can center that middle light fixture above the sofa. It looks uncentered even though it's in perspective. Link to comment Share on other sites More sharing options...
SEIF Posted June 2, 2003 Author Share Posted June 2, 2003 Thank u all for the replies and comments..textures are driving me crazy..i tried hundreds of values to adjust them but i guess iam doing the wrong thing.. At a another trial the solution stopped at 65%..a matter that i dont understand too..it always ranges from 65% to 75% before stopping.. any ideas??.. Link to comment Share on other sites More sharing options...
SEIF Posted June 2, 2003 Author Share Posted June 2, 2003 Ok..here's another trial..now the sun is from the opposite angle.. waiting for comments.. Cheers, Mohammed Link to comment Share on other sites More sharing options...
Alfredo Tapia Posted June 2, 2003 Share Posted June 2, 2003 Hi Mohammed, Looking your images which in my opinion lack of radiosity, and thinking about the unexpected stop of the solution instance, it occurs to me that the problem is that some of the model surfaces (or all of them)are set as “TWO SIDED”. Check their orientation at the .lp file and make sure they are set as “ONE SIDED”, otherwise the light is not going to bounce. Hope it helps. Alfredo Link to comment Share on other sites More sharing options...
SEIF Posted June 3, 2003 Author Share Posted June 3, 2003 Alfredo,u are a genius..i found many surfaces that are two-sided and changed them to one-sided,the solution ran normally to the end. Ok,here's a new one,what do u think? Link to comment Share on other sites More sharing options...
minus Posted July 23, 2003 Share Posted July 23, 2003 I think your plant pots are way over-saturated. --- I would tone down the diffuse on those pots. They look better in the first pic... but even on that one I would turn down the diffuse more. -- Otherwise... looking great I think. Link to comment Share on other sites More sharing options...
SEIF Posted July 23, 2003 Author Share Posted July 23, 2003 thx for your comment minus..i do think that too,although i stopped working on this room recently..but i was intending to work in it again..seems that this is the time :ebiggrin: i'll keep u informed by the latest update.. Cheers, Mohammed Link to comment Share on other sites More sharing options...
SEIF Posted August 1, 2003 Author Share Posted August 1, 2003 well..here's another update,changed some things and materials.. [/img] i guess plant needs to be tweaked a bit to look more realistic,but that can be handled in the final output i hope.. soo,any comments? Cheers, Mohammed Link to comment Share on other sites More sharing options...
animart Posted August 1, 2003 Share Posted August 1, 2003 Cool! Tks its verry pleasure see a good image ofcourse from lightscape. we hope that discreet put his hands to work for a more radiosity solution like lightscape in 3d max and not that poor aproximation, maybe they are only make some chance to brazil and final render to sell some. any way, i verry like that image Link to comment Share on other sites More sharing options...
Ramon Aranguren Posted August 2, 2003 Share Posted August 2, 2003 exelent I always liked lightscape... in fact I made my thesis with it...thinking about I should post some of it so you decide... Link to comment Share on other sites More sharing options...
SEIF Posted August 2, 2003 Author Share Posted August 2, 2003 thanks animart and ramon,u are right indeed,Lightscape is a great tool. but in my openion i feel that the image is a bit " dusty " if u can get what i mean..maybe its the colours,guess i should ask nuno about that if he had time.. :ebiggrin: Link to comment Share on other sites More sharing options...
