Exellite Posted April 13, 2007 Share Posted April 13, 2007 Hi, I'm really new to all this rendering for realism stuff so be gentle I wanted to create an inner city flat with an arched window so decided to model this in my spare time, I still have modelling to do like redo the quilt as it looks very dodgy, also things to add like a rug and some plants and random stuff you would get in a normal bedroom. I will also need to change the background as it is getting affected by the light which i didnt want, the original image is the colour I wanted (not quite sure how to go about doing that, as the image is on a plane behind the window and not a background image). And as you can tell I'm only half way through texturing, apart from that any extra crits are VERY welcome, personally I think its looking ok but its still not looking as real as I want it, also dont watch the quality of the render, its just a test, IR is set to low and I have low light cache settings. kind regards Mark Link to comment Share on other sites More sharing options...
ishpalsingh Posted April 13, 2007 Share Posted April 13, 2007 not bad for first attempt shadows below bed are too dark Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted April 14, 2007 Share Posted April 14, 2007 I think it's pretty good. Reflection on the glass picture is about right. Did you put a fall off in the reflection slot for the wood floor material? I'd work a bit more on the ceiling, and I agree with you about the duvet - it looks dodgy. Also, looking at the city-scape view from my window here, and comparing with your rendering, I think your blacks/dark tones in that background image are far too dark. Perhaps lower the contrast out there and wash out the really dark areas a bit. I think when you finish off your modeling, clean up some of the textures and up the render settings - it should be a simple, but fairly good rendering. Link to comment Share on other sites More sharing options...
MrCAD Posted April 14, 2007 Share Posted April 14, 2007 I really like the render..good work mate..and truly looks real looking at a beginers point of view..so keep it up I am sure once you follow some tips you got you would indeed have some improvements.. good luck Meher http://www.mr-cad.com Link to comment Share on other sites More sharing options...
Exellite Posted April 18, 2007 Author Share Posted April 18, 2007 cheers for the tips guys, much apreciated, when I get some time I'll try and get it finished Mark Link to comment Share on other sites More sharing options...
louis.cho Posted April 19, 2007 Share Posted April 19, 2007 a lot was said so i will only said: you should make some pillows Link to comment Share on other sites More sharing options...
